fengshui-123
Pinkitsch Case
Hi pinkitsch,
See the following picture. The difficult part is whether HDB allow you open window at the South sector indicated on the drawing, at least you should drill or bore some 50mm holes, this will help a lot.
All the 4 red sectors can put moving-water features like fish-tank, water fountains etc.
The stove designed in such a way is to make sure that it is with the red sector and yet has enough space, hope you like it and can implement accordingly.
You can take down the store room and make your kitchen bigger and open concept.
Most important, come back here to feedback your situation after staying.
According to the China Fengshui master (Chen Zheng Ru) I met, "North-South" facing house is one of those that can get excellent fengshui if you fully make use of the 4 red sectors. Really like to congratuation you first.
important note: you must get the measurement proportion accurate.
Edited by fengshui-123
Hi pinkitsch,
Hi renotalk,
what method are you using? Zhen Yin Zhen Yang? What about Yin & Yang of the place? 山山有五行...不現場辨證陰陽五行會出事的。這格局是顛倒還是顛倒顛?
rgds,
Gui
