xarain
Quotation For Condo (brand New)
Hi Folks,
Quick Overview:
Brand New Condo - just TOP - 95 sqm
Reno scope: Minor hacking / removal of some walls, touch up hacked areas, Living Room revamp, Master Bedroom revamp, Wallpapers for the whole house, lighting works
Total Damage: $29,000
Breakdown
1) Hacking / Dismantling Works
To hack existing master bedroom door & door frame $150
To hack existing designated master bedroom walls $750
To dismantle existing master bedroom wardrobe $150
2) Ceiling works
S&C false ceiling with light holder - 100sqft - $400
****/dining - 30ft - $240
S&C false ceiling with light holder - 65sqft - $300
at master bedroom - 20ft - $160
S&C false ceiling at wardrobe area - 40sqft - $280
in master bedroom
3) Masonry Works
S&C designated walls at master bedroom $750
Touch up hacked affected area $280
4) Floor Works
Supply and Lay chengal decking at balcony area - 90sqft - $2300
Supply and Lay designer carpet at partial master bedroom - 58 sqft - $600
5) Carpentry Works
Design and fabricate (D&F) low shoerack using selecting laminate finish (USLF) - 1200mm - $550
D&F dining table with tinted glass top USLF - 1500mm - $750
D&S dining chairs USLF - 4x - $880
D&S suspended TV console using USLF - 1200mm - $550
D&S full height TV Wall panel USLF - 1200mm - $750
Supply & Install (S&I) bay window ledge USLF at:
- Living Area - 3000mm - $380
- Study Room - 2500mm - $350
- Masterbed Room - 2900mm - $450
D&F full height TV feature panel USLF - 2700mm - $1,650
D&F low console for DVD/SCV console USLF at bay window ledge - $390
D&F king size bed frame with storage USLF - 1nos - $1400
D&F suspended side table with glass top USLF - 2nos - $500
D&F low dresser with glass top USLF - 1300mm - $675
D&F display glass shelving and light box at the dresser table - 1300mm - $850
S&I full height mirror and partial tinted mirror at dresser - 32 sqft - $480
D&F sliding L shaped designer wardrobe USLF - 2800mm - $3,150
D&F full height suspended storage cabinet USLF at master bathroom - 800mm - $650
D&F full height bed head feature wall USLF (or cushion / mirrors etc) - 3100mm - $2,300
6) Door Works
S&C door frame using selected veneer finish at masterbed room - 1nos - $250
Supply labour to install existing door at master bedroom - 1nos - FOC
S&I sliding glass door at aster bathroom - 1nos - $450
7) Electrical Works
Supply & run new lightning points for whole house - 44 nos - FOC
Supply labour & install light fixtures for whole house - 51 nos - FOC
Supply labour & shift SCV points **** & masterbed room - 2nos - $250
Supply labour & shift power pts **** & master bedroom - 3nos - $285
8) Misc
Supply commercial floor protection for whole house - FOC
Supply professional cleaners to clean whole house after renovation works - $280
Clearing of debris, uploading & downloading of raw material - $180
9) Wallpaper works
Supply & lay Goodrich Wallpaper for whole house walls, except kitchen, household shelter and yard - 1100sqft - $4500
total : $29,000
:sport-smiley-003:
Comments? wish to clarify more esp. on carpentary works, moving of plugs etc - seems a little costly
thanks all
got $$ to buy a condo..
what is 29K
carpentary always expensive
whacking a wall.. u better check with the management before you go and whack.
It is just TOP, the condo need to pass a check to get a cerf which can't remember what it's call.
If cannot cref due to ur whacking, u need to change all back
Just like medicine in different ward of hospital cost differently. the same panadol in ward A is more expensive than the same panadol in ward C.
Why not u ask for quotation for a 4 room flat, it will be much cheaper. when more or less confirm tell them its a condo.
Hi there!
Sounds about right. Your list of tasks to be carried out is similar to an overhaul, but for a brand new condo, it should have almost everything in place, but then again it's a matter of preference.
We are getting ours done at almost the same costs as yours but ours is 10 years old.
Have you gotten a second opinion?
I reccomend X'clusive Interior down at Katong Mall. Ask for Richard Lau and tell him Brian sent you.
Good luck and let us know how it went.
We can be contacted at brianisnow@yahoo.com.
Edited by bswpy
