scooby3127
Is It Reasonable On The Quotation For A 4 Rm Resale Flat?
Hi all,
Need your advise on the following quotation, thanks in advance!
Is it reasonable on the quotation for a 4 rm resale flat at 108 sq. Quoted in total at $40k for the follwing items of work to be done.
MAIN ENTRANCE
To supply and install 1 no. of designer's door c/w laminated frosted glass
LIVING HALL
To fabricate and install full height Shoe cabinet in selected laminate finishes ( 6 ft )
To fabeicate and install wall panel c/w cantilever TV console and 3 nos. of drawers in selected laminate finishes(L=2700mm X W=400mm X H=300mm)
To suuply and install false ceiling c/w recess light
To supply 4 nos. of pole divider in selected laminate finishes
BEDROOM 2 ( GUEST ROOM )
To supply and install simple cornice
BEDROOM 3 ( STUDY ROOM )
MASTER BEDROOM
To fabricate and install TV wall panel in selected laminate finishes ( 3 ft )
To supply and install Bed head wall panel c/w 2 nos. of side table
To supply and install false ceiling and recess light
MASTER TOILET
To supply and lay ceramic wall tiles ( Tiles @$2.50 p.s.f. )
To supply and lay ceramic floor tiles c/w water-proofing ( Tiles @$2.50p.s.f.)
To supply and install frameless tempered frosted glass shower screen
To supply and install frosted glass swing door ( 3 ft )
To box-up water pipe using cornice board with recess light
To fabricate and install wall hung vanity cabinet c/w frosted glass door and aluminium frame and solid surface top ( 2 ft )
To supply and install frameless wall mirror ( 4 ft X 3 ft )
To supply and install Naco window ( 1 set )
COMMON TOILET
To supply and install PWC Aluminium swing door c/w acrylic panel
To supply and install PWC aluminium 3 panel of shower screen ( 5 ft )( Include the kerb )
To supply and install exhaust fan with fixed glass panel (Brand :KDK@$140 )
KITCHEN
To supply and lay ceramic wall tiles on exposed area ( est.260 sq ft. )
( Include supply and lay moasic tiles at Cooker & Sink area )
( Tile @$2.50 p.s.f. )
To supply and lay ceramic/Homogeneous flooring c/w water-proofing
( Tiles @ $2.50 p.s.f. )
To construct kitchen cabinet, washing machine and fridge base
To supply and install Bottom kitchen cabinets in selected laminate
finishes ( 18 ft ) c/w
a) Stainless steel Dish-Rack b) Cultery tray c) 4 nos. of drawers
To supply and install solid surface top ( 15 ft )
To supply and install 1 no. of stainless steel rubbish chute ( Flat type )
Construct kitchen wall with half tempered glass & slinding door
PLUMBING WORK
To supply labour to install 2 nos. of W.C. , 2 nos. of Basin, 1 no. of Sink,
1 no. of Washining machine pointt, 1 no. of storage heater and toilet
accessories
To supply & install stainless steel water pipe at kitchen & 2 toilet
( Inlcude 2 nos. of Hot and Cold points )
OTHERS WORK
To paint whole house with ICI/NIPPON emulsion paint
To supply and lay 600mm X 600mm China homogeneous tiles c/w skirting
****/Dining and 3 Bedrooms ( Tiles @$3.00 p.s.f.)
HACKING WORK
To hack existing wall & floor tiles at 2 nos. of toilet and kitchen, hack
exsiting floor tiles ****/Dining & 3 Bedrooms and dismentle existing
kitchen cabinet ( Include Sand & Hauluage Charges )
Acid washing for whole house
ELECTRICAL WORK
To supply and install electrical work for whole house ( As per attach list )
OTHER WORK
To supply and install Natural casement window and grilles at Balcony
To Relocate & add on a fan coil in the living hall
Guest tommy_moby
with such renovation at 40k consider ok la.. did u try asking for more quotation? i believe u will be able to get a cheaper quote elsewhere. if u r keen u may try my ID.
Hi all,
MAIN ENTRANCE
LIVING HALL
MASTER BEDROOM
MASTER TOILET
COMMON TOILET
KITCHEN
PLUMBING WORK
accessories
OTHERS WORK
HACKING WORK
ELECTRICAL WORK
OTHER WORK
agree with tommy, quite extensive list.
Guest tommy_moby
hanni perhaps you can help by providing your id contact for scooby to try..
A better question to ask is whether the guy can do a quality job.
Thanks for all the feedback, so you all think 40K is worth la? Workmanship is good, been to the site before.
So u all think is worth bo? I been to the site, workmanship is good.
