ene 1 Report post Posted May 19, 2008 Hi there, Due to our very limited kitchen space, I am intending to get a convection oven that can do almost everthing - bake, grill, microwave, etc. I saw a Panasonic NN-C784MFYPQ which seems quite capable and reasonably priced (about $370). Any good recommendations or comments? Share this post Link to post Share on other sites
BunBun 5 Report post Posted May 19, 2008 (edited) This is ideal for those who do not want to have built in oven if they are not going to use one for long term purpose, ie; baking. Furthermore those who want to use oven for baking, it is better to go for built in oven partly 'cos built in oven can bake at least 2 batches at a go than having to bake 1 batch at a time in between intervals. Quite time consuming. Do note that this is not an convectional oven. Its a microwave oven with convectional function only However, if need for practical use than baking, then microwaving, grilling and etc is good since it means you will use the oven more for cooking and etc. Im using this type of inverter oven and so far I do not have any problems using it. Just that my only complaint is that i need to bake cupcakes (1 batch) at a time at intervals since I am currently learning to bake. Edited May 19, 2008 by BunBun Share this post Link to post Share on other sites
icegal 0 Report post Posted May 19, 2008 I'm also looking for a convectional oven. Just saw a sharp model R888F costing abt $429. It stated that it can be used for grilling,baking and microwave function. I'm planning to do some light baking so dun feel the need to get a built-in oven. Can anyone help mi to verify whether is the model that i mention above a convection oven? Thanks! Share this post Link to post Share on other sites
BunBun 5 Report post Posted May 19, 2008 Usually convectional oven does not have microwave function as convectional oven does not require microwave waves or radio waves to heat food actually. Believe the model, Sharp R888F mentioned is a microwave oven with convectional function actually. This can be googled online for more reference. Share this post Link to post Share on other sites
RinoaHeartily 0 Report post Posted June 11, 2008 I am also considering this model. Another one worth lookin at is samsung CE1071A The sharp microwave/convection oven looks ugly especially the back.. May i know for baking fries.. or making crispy food is this "oven" good enough? Share this post Link to post Share on other sites
ene 1 Report post Posted June 12, 2008 Usually convectional oven does not have microwave function as convectional oven does not require microwave waves or radio waves to heat food actually. The Panasonic model I posted above has microwave function as well which is why I'm considering it. For my purpose, I'd probably be a lot of microwaving and the occasisonal baking/grilling. This model does not have a steaming function but I don't need it. FYI, those considering, can go to Goh Ah Bee @ Hougang St 21. They're selling it for $370 which is a very good deal. I've already done a lot of market survey Share this post Link to post Share on other sites
springlovely 0 Report post Posted June 13, 2008 Hi all, if anyone is interested, I have a sharp microwave/convection oven to let go at $180/- (no warranty but used less than 10x as I have ano. oven). The model is R888C (Grey). The back of the oven is not flat but it's a good buy at this price I've posted sale under the Garage sale forum. Anyone interested can sms me at 97802303. Share this post Link to post Share on other sites
BunBun 5 Report post Posted June 13, 2008 ene, i was referring to those fan forced oven ie; convection oven...cos those ovens don't have microwave function and I believe that was the question that icegal is asking about this sharp model. Not the convectional ovens cos those are the ones that come with microwave function, paiseh. The Panasonic model I posted above has microwave function as well which is why I'm considering it. For my purpose, I'd probably be a lot of microwaving and the occasisonal baking/grilling. This model does not have a steaming function but I don't need it. FYI, those considering, can go to Goh Ah Bee @ Hougang St 21. They're selling it for $370 which is a very good deal. I've already done a lot of market survey Share this post Link to post Share on other sites
Starscream 0 Report post Posted June 15, 2008 I'm looking at this Bosch Oven. Any comments? Will be buying a Microwave Oven separately HBN331E2J Product features • Stainless steel colour with bar handle • Multi-functional oven with 6 heating methods: - Conventional top and bottom heat - Bottom heat only - 3D hot air - Hot air grilling - Variable grilling for large surface - Rapid heat-up (Manual) • Hot air heating-up duration: 8.3 mins • Maximum oven temperature 270°C at normal mode • Electronic clock with timer • Rotary knobs • Double glass door • Cooling fan • 4 shelves position • Childproof lock • Removable door for easy cleaning • 1 pc circular oven lighting on top at 25W • Supplied accessories: 1 universal pan, 1 split grill tray Technical information • Cavity volume: 52 litres • Total connected load: 2.9kW • 220-240V/50-60Hz/13 Amp • Cable length: 1 m Appliance dimensions: 595H x 595W x 548D mm Cavity dimensions: 323H x 382W x 423D mm Built-in dimensions: 575-597H x 560W x 550D mm Share this post Link to post Share on other sites
RinoaHeartily 0 Report post Posted June 16, 2008 slightly off topic... are you guys worried about the "effect" from cooking via microwave? i spend quite sometime searching on the effect of cooking via microwave.. you know once you buy a microwave, u will be using it frequently because cooking is so god **** easy and fast... Share this post Link to post Share on other sites
ene 1 Report post Posted June 17, 2008 slightly off topic... are you guys worried about the "effect" from cooking via microwave? i spend quite sometime searching on the effect of cooking via microwave.. you know once you buy a microwave, u will be using it frequently because cooking is so god **** easy and fast... Yes, I know where you are coming from. I used to think about it before but now, I just use it. I just make sure I don't stand too close by when it's heating up food. Share this post Link to post Share on other sites
Sexyviper 0 Report post Posted June 18, 2008 I'm looking at this Bosch Oven. Any comments? Will be buying a Microwave Oven separately HBN331E2J Product features • Stainless steel colour with bar handle • Multi-functional oven with 6 heating methods: - Conventional top and bottom heat - Bottom heat only - 3D hot air - Hot air grilling - Variable grilling for large surface - Rapid heat-up (Manual) • Hot air heating-up duration: 8.3 mins • Maximum oven temperature 270°C at normal mode • Electronic clock with timer • Rotary knobs • Double glass door • Cooling fan • 4 shelves position • Childproof lock • Removable door for easy cleaning • 1 pc circular oven lighting on top at 25W • Supplied accessories: 1 universal pan, 1 split grill tray Technical information • Cavity volume: 52 litres • Total connected load: 2.9kW • 220-240V/50-60Hz/13 Amp • Cable length: 1 m Appliance dimensions: 595H x 595W x 548D mm Cavity dimensions: 323H x 382W x 423D mm Built-in dimensions: 575-597H x 560W x 550D mm Looks cool. Do u hv the price? Share this post Link to post Share on other sites
Starscream 0 Report post Posted June 18, 2008 Should be $600++ Looks cool. Do u hv the price? Share this post Link to post Share on other sites
LittleDevil 0 Report post Posted June 19, 2008 Yes, I know where you are coming from. I used to think about it before but now, I just use it. I just make sure I don't stand too close by when it's heating up food. But I thought I seen it somewhere that mircowave technology actually involve breaking up some cells (?) within the food to cook it fast. So the food which you consume at the end of the day may not be healthy. I would suggest to get a convection oven (baking/grilling) plus a steamer/steam oven (reheat/steaming). Share this post Link to post Share on other sites
SmartFool 0 Report post Posted July 1, 2008 Starscream can advise where to buy this? i would like to take a look at it as well thanks Share this post Link to post Share on other sites
