jwelby 0 Report post Posted November 28, 2016 Hi I am renting an old HDB unit. One of the taps is leaking (dripping) and before I do the repairs, want to kill off water supply to the whole unit. Attached pic is what the water supply pipe arrangement outside my unit looks like.. The shaft that sticks out (circled in pic) is grooved. There are no other valves available. Am I supposed to turn the shaft using a wrench to cut off the supply? Or get some proper valve handle that will slot into the grooves of the shaft and then turn using that? Checked the staircase landing and that has only a single big red shutoff valve. Probably for the whole floor. Share this post Link to post Share on other sites
smermil 1 Report post Posted November 28, 2016 hello, i would strongly advise of touching this until i get a sign off from the owner since you are just renting.. my 2 cents Share this post Link to post Share on other sites
w7_lee 11 Report post Posted November 28, 2016 The shaft you circle is correct. At the end, it should be a square. You can buy a proper handle from the neighbourhood hardware shop to slot into the square end and close the valve. Just take a pic and show it the hardware shop seller. If using a spanner/wrench, you need to be more careful. It's brass, so it's soft and will damage easily. Normally there is a valve below each tap to let us cut off water to that tap, so you don't need to cut off supply to the whole house. But you mentioned it is an old house, so not sure if it's available. You'll need to look below the sink. Good luck. Share this post Link to post Share on other sites
wroomwroom 5 Report post Posted December 10, 2016 It is correct. I normally use an adjustable wrench to turn off the supply. Must identify which is yours otherwise you end up turning off your neighbor's supply. Share this post Link to post Share on other sites
bepgof 20 Report post Posted December 25, 2016 Either this or that Share this post Link to post Share on other sites
